Old 08-04-2016, 11:58 AM   #1
PeteAndEd's Avatar
Stairs
2015 FR3 30DS Here...
Just wanted to report that our stairs are starting to hang lower on the left than the right when retracted or extended (see pic 1). It has been slowly getting worse over time. I finally crawled under to see that the frame where the left side of the stairs was attached seems to be bending down (see pic 2)
Our rig is beyond the 1 year bumper to bumper warranty. I contacted the service department at FR and said I felt this was a safety issue and asked what FR would do about it. Much to my surprise, they said to take it back to the dealer and FR would pay for the repair!
http://www.forestriverinc.com/ContactUs.aspxService
ID:	116279   Click image for larger version
FR3 2015 30DS
PeteAndEd is offline   Reply With Quote
Old 08-04-2016, 12:12 PM   #2
HAPPY WHEN RV'ING
drivmsafe's Avatar
WOW!! That's quite a bend. Looks like a gusset is in order to give that area some strength. But, the more I look at pic #2, it looks like they had some kind of a gusset on the side frame attached to the lip. Probably some shoddy welding there. I'll be keeping a watchful eyes on ours.
Thanks for the heads up.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 08-04-2016, 12:55 PM   #3
Kadiddle's Avatar
I had exactly the same failure. My vehicle had previously been to a show so I blamed all the heavy people going in and out. The dealer welded the broken "L" shape back in place. However, a few month later, the weld gave way. I took a length of bed rail and put it on top of the existing mounting bracket (~11") to more than double the material there and to distribute the weight across that bracket. So far, so good but who knows. As with many things in this coach, I refer to it as "An insufficient design". The point that fails gets over 500 ft-lbs of torque on 1/8" bent steel. I'm 6'3" and over 200lbs.
2015 FR3 30DS
2010 Ford Escape Toad -or- 2012 Ford Focus Toad
Kadiddle is offline   Reply With Quote
Old 08-04-2016, 01:15 PM   #4
PeteAndEd's Avatar
I'm over 200# as well. I think the natural tendency is to exit the coach on the right side of the stairs to avoid hitting the door. I'm guessing it gets more use than the left side when exiting. A steel plate and/or perhaps more bolts should fix the problem. Called my dealer - no appts for almost 2 months.
FR3 2015 30DS
Old 08-04-2016, 01:33 PM   #5
HAPPY WHEN RV'ING
drivmsafe's Avatar
Hey kadiddle, peteanded. On another subject. Looks like we are all about the same size and weight. Have either of you been up on the roof of your coach?
I'm a little leery. I'm 6'3", 240.
Old 08-04-2016, 01:42 PM   #6
PeteAndEd's Avatar
Yes, several times. The ladder is a little wobbly, but I'm not afraid of it and the roof seems quite stable. Careful of the edges! Also, the first step up and last one down is quite a distance from the ground - you might want to start going up the RV ladder from a stepladder.
FR3 2015 30DS
Old 08-04-2016, 02:43 PM   #7
Kadiddle's Avatar
Truth be told my "over 200" is around 240. Yes, I go up on the roof. The FR3 ladder is closer to the body than my previous coach hence less movement. Other than having less space for my size 13 feet, it's more stable. Be careful not to twist your feet with weight on when on the roof. I live in the northeast and go on the roof every winter storm to clear. After one winter, I can see some footsteps in the roof. Covers never worked for me.
Also agree with the comment that we all put our weight on the left corner of the stairs (facing coach from outside) to avoid the door. Hence, that's the side that is seeming to fail. Curious if there are to be many FR3 owners with this stair failure mode such that maybe there will be a safety recall.
2015 FR3 30DS
Old 08-04-2016, 02:57 PM   #8
lickem66's Avatar
Ours is not of the best quality either so I put a couple of these under the last step when we get to camp.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2016 FR3 28DS
Past 2012 Forest River Rockwood 2104.
lickem66 is offline   Reply With Quote
Old 08-04-2016, 02:57 PM   #9
HAPPY WHEN RV'ING
drivmsafe's Avatar
Thanks for the input guys. When I've washed the coach in the past I had a neighbor teen that would go on the roof for the wash. The family has moved so now I guess I'll trek up and do it myself. ��
Old 08-04-2016, 03:22 PM   #10
Kadiddle's Avatar
Originally Posted by lickem66 View Post
Ours is not of the best quality either so I put a couple of these under the last step when ........
We, after spending the kind of money we've spent on our coaches, should not have to tolerate having to support our steps when deployed. Our any other kind of work arounds due to poor design, quality, or workmanship. Just saying...........
2015 FR3 30DS
Old 08-04-2016, 04:16 PM   #11
Broken Stairs
We've had the same issue . . . twice! The first fix didn't last long; so far the second fix is holding.
David and Cindy
Rowdy (Shih-Poo) and Lexi (Goldendoodle)
Flagstaff E-Pro E19FBS
David and Cindy is offline   Reply With Quote
Old 08-04-2016, 04:30 PM   #12
Jim Wiemels's Avatar
Our 2016 FR3 is scheduled 8/15/16 for a list of warranty work, one item which is sagging stairs on the left hand side (see photo)Click image for larger version
Name:	ImageUploadedByForest River Forums1470345946.428277.jpg
ID:	116300 While looking underneath I couldn't really see the cause of the problem but thought may be a loose bolt and nut or broken weld. Hopeful will know for sure soon. Thanks for everyone's insight. Happy motoring. Jim
Jim Wiemels is offline   Reply With Quote
Old 10-10-2016, 09:25 AM   #13
PeteAndEd's Avatar
Got our RV back from the dealer. They feel quite solid again. No charge (FR paid for the repairs)... the paperwork says they removed the step and wiring, straightened metal, welded broken section back together and added material for extra support.
FR3 2015 30DS
Old 01-04-2017, 12:37 PM   #14
Our stairs failed to. Our dealer said two things, the way the door opens forces you to step in the same place every time, and the stairs are not the best quality. Our dealer re-welded and reinforced. FR paid for it.
linchat is offline   Reply With Quote
Old 01-04-2017, 02:27 PM   #15
Hmmm something weird happened to our steps... the metal steps outside were fine but the indoor steps used to sink down two inches they fixed it but it was strange
2015 fr3 towing a Suzuki grand vatara
colourful64 is offline   Reply With Quote
Old 03-03-2017, 12:12 PM   #16
Had the same problem with mine was not the steps themselves the cheap metal they used to both the steps to actually tour I rewound it and install quarter inch steel reinforcement plates steps are solid now
anthony mazziotto is offline   Reply With Quote
Old 03-20-2017, 06:14 AM   #17
wayne and sherry's Avatar
Can you please post any pictures of your repair ?
wayne and sherry is offline   Reply With Quote
Old 03-20-2017, 07:19 AM   #18
Left Coast
why not put a better step system on? That problem also happens to trailers also
Old 03-21-2017, 08:56 AM   #19
I had same exact problem as have many other with the stairs on FR3. Forest River is going to fix it, there might even be a recall on it. But they know the stair problem on the 2016.
stair, stairs
