01-11-2010, 03:52 PM
#1 | | Junior Member
| sunseeker fusebox
hello, i live in a sunseeker, with 30amp connection, plugged in 2 space heaters and blew a fuse. i have power to microwave, gfi circuit, but refridgerator and lighting are out. cant find a fusebox anywhere or owners manual. any help will be appreciated. thanks, bb
01-12-2010, 05:51 AM
#2 | | Senior Member
I have found that the owners manual does not tell you where they put the equipement, my fuse box is inside under the oven. It is a brownish looking box and the lid comes down and the fuses are there. Hope this helps.
__________________ |
01-12-2010, 06:25 AM
#3 | | Senior Member
| Quote:
Originally Posted by doublbleb hello, i live in a sunseeker, with 30amp connection, plugged in 2 space heaters and blew a fuse. i have power to microwave, gfi circuit, but refridgerator and lighting are out. cant find a fusebox anywhere or owners manual. any help will be appreciated. thanks, bb | It sounds like you had both heaters plugged into the same circuit. You tripped the breaker that protects that circuit. You'll need to see what other receptacle is still working so you can plug the second heater into that receptacle. Once you do this you should be fine until you want to use the microwave. If you're using 2 -1500 watt heaters you'll need to turn one off in order to avoid tripping the main 30 amp breaker where you're plugged in.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
01-13-2010, 08:07 AM
#4 | | Happy to Be Camping
Join Date: Aug 2009 Location: We live in Rhode Island, but our hearts are in New Hampshire
I have a Sunseeker and my fuse box/load center is under the rear bed, accessible from the foot of the bed by a cover.
08-31-2010, 06:50 PM
#5 | | Junior Member
I blew a GFI, Ground Fault Interrupter, once. It was located in the bathroom but protected an outlet near the kitchen sink and an outlet outside under the awning. So that would be something to look for as well.
| |  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Sponsor Links | | | » Recent Threads | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | » Online Users: 48 | | 18 members and 30 guests | | bwssr, cat1956, Dave_Monica, dezolen, donjuanss, Emptypockets, grhodes50, Jewels, lbtex, mtnguy, revrnd, TJ1975, tncruiser, toddwilson, trailraider, twalk47, WildPlumYonder, wrinkles | | Most users ever online was 240, 05-22-2010 at 07:00 AM. | |
